Old 09-09-2012, 09:49 PM   #1
rod
Liked 20 Times in 15 Posts
Default 327 SBC block ?
I am in the process of building a 327 race only engine. I have a '63 block which has a crack line about 1" each side of the block drain, both sides, outside only. i can fill it with hard block OR i have a '64 block which is OK.
the '63 block is no good as is, so i don't mind filling it.
what would you do?
thanks
rod in AZ
rod is offline   Reply With Quote
Old 09-09-2012, 10:38 PM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: 327 SBC block ?
the cracks can usually be repaired fairly inexpensively and then it can be filled if you wish, but it's not necessary.
Phil Molski
PMR Performance
S/C 1623
Old 09-10-2012, 12:08 AM   #3
55 Chevy
55 Chevy's Avatar
My 265 had a similar crack on one side. Since this was such a rare block I had it stitched then patched up with Belzona epoxy.
55 Chevy is offline   Reply With Quote
Old 09-10-2012, 10:11 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I would use pinning process,Lock-Stitch has a good product ,pin it and seal up completely
then hard block, hard block may not stop a leak I have seen water leak past it so I would'nt rely completely on block filler sealing a leak.
Mike Taylor 3601
Old 09-10-2012, 10:32 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
You would be much better off going to a 4 bolt main block. The small journal blocks were proned to cracking cylinders. No sense starting off with something thats damaged.
Mike Pearson 2485 SS
