Old 08-24-2012, 07:23 PM   #1
m.megaw
Default 1968 dart for ss
Im working on a dart for superstock with a stick.What would be the best motor combo 340 383 440? I dont need to set a record at this point in time however must be respectable.
monte
m.megaw is offline   Reply With Quote
Old 08-24-2012, 07:26 PM   #2
GTX JOHN
Liked 2,435 Times in 688 Posts
Default Re: 1968 dart for ss
All three have very competitive HP rating and are Excellent!
It comes down to your personal preference.
Old 08-24-2012, 10:49 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
And your bank account. A competitive SS 383 should run about $35,000.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-25-2012, 05:44 AM   #4
GTX JOHN
I think all the above combos cost about that...... the 340 might be slightly
cheaper. The protrans and the heads are a bit less from my experience
for the small block but not a ton cheaper.
Old 08-25-2012, 02:58 PM   #5
Jared Jordan
Liked 523 Times in 117 Posts
Send a message via AIM to Jared Jordan
I'm a big fan of the Super Stock 383 combo. It's got a good factor (300 hp) and enough carb for the cubes. Don Little, Steve Wann, Mike Cotten, and others have run very well with it.
The 440 is fast as well. Not very many 340's out there. I'm sure there's a good reason for that. Head CC's maybe?
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 08-25-2012, 06:10 PM   #6
GTX JOHN
Jared: The 340 around 280 in SS last time I looked........It is 293 in stock
and still Fast.
The carb is same size Carter on 340 and 383 as I recall.
NHRA changed spec on X heads a while back to 167 after a bunch
of fighting which is a decent number for small block mopar heads.
The main reason I run the stock legal engine in Super Stock rather than
a ever build a real SS engine is that is very difficult to find a cylinder head
builder for SS out west. My friends that do my stock stuff are not very
interested. I left a set at a well know Head Place and he left them on the
Shelf for two years.
When I run the 340 Stocker in SS......it run slightly under to SS index and
and I think it would sure pick up in SS trim.
I agree that all three are good combinations!
Jared: I hope you Legendary Grandfather is doing well
He has always been a Hero of mine since the 1960s!!
Old 08-25-2012, 07:01 PM   #7
magnumv8
What you need to keep in mind now is that the Edelbrock heads are only legal on the 318, 383 and 440 in the Dart for '68 and '69....the 340 can only use the "iron" head replacement.....the 318 taken out to max specs is around 330 cubes and looks as good or better than the 340 package w/Edelbrock heads in SS
D L Rambo......
magnumv8 is offline   Reply With Quote
Old 08-25-2012, 07:47 PM   #8
Ed Wright
Ed Wright's Avatar
I would sure think about a 383". That thing of Mike Cotten's is very fast.
Ed Wright 4156 SS/JA
Old 08-25-2012, 08:11 PM   #9
Paul Precht
Paul Precht's Avatar
Liked 307 Times in 116 Posts
D L Rambo......
A .070 over 318 is about 323 ci and the 2 brl carb flows about 300 cfm, not a good choice IMO. The 383 is the best choice, the BB head is far superior and much easier to achieve the flow needed to be competitive , much of the money spent is on parts and labor needed to make the engine live at high RPM.
Paul Precht is online now   Reply With Quote
Old 08-25-2012, 11:00 PM   #10
Todd Boyer
Liked 6 Times in 5 Posts
Shawn Blair runs a 383 in his '68 Dart SS/JA.
