Thread Tools | Search this Thread | Display Modes |
08-23-2012, 10:18 AM | #1 |
Stocker Motor for sale - 350 c.i. 300hp combination sbc
For Sale Stocker Motor - 350 c.i. 300hp combination small block Chevy $4500.00 obo
(I have records for all dyno pulls on Burtonsville machine dyno) Best ET at legal weight & motor for a 1969 Nova in G/SA was 11.485 @115.6 mph (36 runs on motor short shifting in bracket mode 95% of the time) • 292 casting heads prepped by Burtonsville machine Hollow stem Ferrea valves Burtonsville valve job Crane harden rockers ARP pro series rocker studs Psi springs GM light weight retainers Harden locks *To be noted (no acid porting) plenty of potential left within these heads • Intake NO acid porting or intake modification Carb pad resurfaced Intake flats resurfaced *I have another intake that has a lot of work done to it, it’s almost two tenths faster than the stock intake / modified intake was not dyno with motor • Short block 010 GM casting bored .060 over Decked Lined honed Coated cam bearings • Valve train Bullet Cams Burtonsville proprietary grind Smiths Machine lifters • Pistons CP pistons Coated (Swain Tech Coatings) Full floating Precision Products wrist pins Burtonsville Machine special gapless ring package • Crank Reground to maximum allowed offset (per NHRA rule) Fluid dampener (sfi approved) • Bearings/Gaskets Calico bearings One piece Felpro oil pans gasket Felpro head/intake gaskets • Corvette oil pan Oil pump highly modified • Leon Miranian prepped Q – Jet Contact Peter Kivett @ 443.306.3583 at any time. (please leave a message if I can't answer the phone) |
01-19-2013, 08:03 PM | #2 |
Liked 5 Times in 2 Posts
Re: Stocker Motor for sale - 350 c.i. 300hp combination sbc
U still have motor or any parts for sale?
