Old 08-20-2012, 01:33 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Garage Sale
15x10 Cragar Super Tricks (Multi bolt pattern with a 5 inch backspacing) in great shape with fairly new Hoosier LT weight 30x9 radials slicks (CO6). Wear indicators are approximately .110 deep. Local pickup only on the wheels. I will have them at the Fitchburg Massachusetts Airport Nostalgia show on Sept 8th - $400 OBO for the set, which includes the Hoosiers already mounted and balanced.
MSD 7AL-3 (Red Box) - $325
All items below are priced and best offer.
Barry Grant 280 Fuel pump with BG 2 port regulator - $175
Holley 750 Vac Sec 3310 with quick vac spring changer- $175
New Canton Fuel Filter #26-602 and O-Rings #26-820 that fit the Black BG-5000 style canister filter - $10
Moser 33 spline axles 20 ¾ inches on each axle (Outside flange to end of axle) for a Chevy 12 Bolt with a bolt in Chrysler bearing, ½ studs, 4.5 Bolt Circle - $50
Ford 8"/9” 28 spline mini spool - $15
N/A
mannymen is offline   Reply With Quote
