Old 08-07-2012, 10:40 PM   #1
DIV3CR
Liked 3 Times in 1 Post
Question Sonoco racing fuel
Has anybody tried mixing Sunoco race fuel (STANDARD) 110
octane with a gasoline about 92 octane with a 50/50 mix?
If so how did it perform? I have a 350 H/SA with about 10:00-1
compression.
Thanks
DIV3CR is offline   Reply With Quote
Old 08-08-2012, 12:09 PM   #2
Mike Graham
Liked 341 Times in 67 Posts
Default Re: Sonoco racing fuel
compression.
Thanks
I have done it in a street car. Works fine. It will not pass fuel check for stock.
Mike Graham is offline   Reply With Quote
Old 08-08-2012, 12:57 PM   #3
Mike Croley
Mixed fuel will not pass IHRA or NHRA fuel check . That's true of blending two or more brands of race gas together , or mixing race gas with pump gas. The specs used by fuel check are for specific fuels . You tell the tech man what brand and what octane you have and he checks your sample against the specs for that particular brand and octane .
Mike Croley is offline   Reply With Quote
Old 08-08-2012, 01:02 PM   #4
Mike Croley
If you don't have to worry about passing a fuel check , mixing good quality premium with a good race gas works fine .
