Old 08-06-2012, 10:27 PM   #1
PROGXP
Default Parts for sale off 399ci Australian Pro Stock Max effort SBC
Parts for sale off 399ci Australian Super Stock Max effort Small Block Chev.
Parts for sale off 399ci Australian Super Stock Max effort Small Block Chev. Suitable for Australian Pro Stock, ANDRA / NHRA Competition Eliminator, Super Stock or big cubic inch N/A Outlaw
• Jesel Camshaft Belt Drive, Jesel Belt Drive Distributor and MSD plug leads. MSD Digital 7 fibre optic sensor on # 1 plug lead. $1000
• MSD Flying Magnet Crank Trigger with pickup. $250
• ATI Super Damper + pointer $250
• Meziere SBC water pump in Black. $200
• CFE SBX-A Cylinder heads CNC ported by TRE for 4.400 bore space. Cyl #4 has had a small repair due to some peppering. Repair will be OK in service. (see photos.) Jesel Rocker gear (plus spares) with tool steel adjusters, PSI springs, Titanium valves, Titanium Retainers and coated Titanium Locks. 4 corner cooling or plugs for front only cooling. TRE Billet Runner intake manifold with adjustable plenum volume and Star Vacuum Relief Valve fitted to valley cover. Carb linkages on manifold to suit carbs below. $9500
• 2 x Dominator carbs updated by Bob Book with Braswell components for ERC fuel (no jets).Magnafuel 4-port regulator with insulated Speedflow lightweight hoses. $3500
• Billet Shear plates x 2 to suit carbs and manifold. $250
• Jesel Bronze insert pushrods x 16 (Can be shortened to suit new length.) $500
• Jesel Keyway roller lifters x 16. $500
• 3.570” Stroke Crower Lightweight REM polished Crankshaft. Large Journal mains, Honda big end. $1750 (picture to come)
• All you need to complete the motor is a block, pistons, rods, and camshaft!
• This package went 7.44 @ 182.97 in Haas GXP at 6lb/ci (399ci and 2400Lb) with 3spd auto (no -250Lb in Aus for the auto) at 1.03 correction factor. All parts are in good condition with dyno time and a total of 46 passes on them. Going in a different direction now and need to move them on.
• Would like to sell the lot for $16,000 USD with air freight to you in the USA included, or buy all the parts separately for a total of $17,700 USD plus freight costs. I will provide all fund transfer details and ship as soon as payment is received. If you buy the lot, all parts will be boxed and wrapped on a pallet for delivery. Photos of all parts available on request.
• A1 Torque converter to suit above combination. 30 passes on converter. $750 USD (if you buy it with the engine parts above I’ll throw it on the pallet with no extra freight charges.)
• 5.25: 1. Mark Williams Diff centre. Low drag ball bearing pinion support, Lamb/Richmond 9.5” Cryo pro gears and 40 spline Aluminium spool. Aluminium yoke. 15 passes. $1500 USD (if you buy it with the engine parts above I’ll throw it on the pallet with no extra freight charges.)
For all photos go to http://s1240.photobucket.com/albums/gg490/PROGXP/ and check them out.
Darren Parker
Darrenp@socobell.com.au
Darren Parker
B/APA Australian Super Stock
Or Aussie Pro Stock
Haas GXP with Ridgeway power.
See my Blog:
http://www.vdrc.org.au/racers/racer-...en-parker.html
PROGXP is offline   Reply With Quote
