Old 08-06-2012, 08:28 AM   #1
Jim Kaekel
Liked 529 Times in 107 Posts
Default Bellhousing Breakage
I found this past weekend on my '70 Olds 442 D/SA that I've got a crack in the bellhousing. This is the second one in the last two years. Transmissions are TH-350 behind a real torquey Olds 455 that runs high tens. I use stock motor and transmission mounts, and have a turnbuckle mounted from the frame to the LH cylinder head. Over 25 years of racing this car, I have only broken a few bellhousings, but now have broken two in two years. A machinist friend suggested that the transmission cases probably get fatigued after so many years of racing. We both think that I should add a brace to the RH side of the transmission case that some guys are using that joins the bosses at the front and rear of the case. Thoughts? Experiences?
Jim Kaekel 3836 STK
