Old 08-05-2012, 09:15 PM   #1
VStock
Default Racing gas, low compression, and ignition timing
I'll admit up front that I have no experience with today's racing gas. How does it compare to the old leaded gas? How does it do in a low compression engine, say 8.5-1? Can you run a lot of advance without knocking?
Marty Knox
VStock is offline   Reply With Quote
Old 08-06-2012, 06:56 AM   #2
tj310
Default Re: Racing gas, low compression, and ignition timing
I believe todays super unleaded pump gas is better than it was 20 years ago . Just start at 32* and add a couple see if it's faster. --- Trevor
Old 08-06-2012, 11:00 AM   #3
Mike Croley
A low compression engine like the one you describe works just fine on pump gas as long as it's premium . Two things to keep in mind . First , stick with one brand from one trusted station . Shell or Chevron are the best choices .
Second , don't increase advance more than a couple of degrees at a time and rely on plug readings and timing slips to tell you when you hit it right .
Mike Croley is offline   Reply With Quote
Old 08-06-2012, 01:16 PM   #4
VStock
I'm more concerned about using something that will pass the fuel check at an NHRA event.
Marty Knox
Old 08-06-2012, 01:28 PM   #5
7423
In my 9.0-1 Ford 5.0, premium unleaded pump gas is .05 faster than anything that VP sells that is legal for NHRA in stock.
At over $10 a gallon, it should be a crime to force us to use it instead of pump gas.
7423 is offline   Reply With Quote
Old 08-06-2012, 01:29 PM   #6
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
The last load of legal fuel through my V-stocker was C11.....not cheap but we don't use much!!
Dave Turner
SS/GT #1153
Old 08-06-2012, 01:36 PM   #7
Dave Turner
Amen Charlie.
Dave Turner
SS/GT #1153
Old 08-06-2012, 02:44 PM   #8
Mike Croley
If pump gas is legal for your class , premium from Shell or Chevron will do nicely . If you need race gas , Renegade Racing Fuels are legal in IHRA and NHRA and will pass fuel check as well . And a lot less money per gallon .
Old 08-06-2012, 05:29 PM   #9
Ed Wright
Ed Wright's Avatar
Marty, what kind of engine are we talking about? Combustion chamber has a big effect. Not just compression ratio.
In this case I would try the lowest octane of the accepted fuels.
Ed Wright 4156 SS/JA
Old 08-06-2012, 06:16 PM   #10
VStock
It's a Chevy 230 6 cylinder.
Marty Knox
