Old 07-28-2012, 01:08 AM   #1
corky
corky's Avatar
Liked 4 Times in 4 Posts
Default Just Bad Luck
Caroline? Out of a 52 car field how can you draw the only other J car the first round? I always have that luck back here in S. Dak. in our s/ss races. Corky , the other red Camaro.
corky is offline   Reply With Quote
Old 07-28-2012, 08:30 AM   #2
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Re: Just Bad Luck
If you're not the faster of the two, that's very bad luck.
But I thought in the S/SS combo races with no scales, no fuel check and no teardown, it was strictly a dial your own, even if both were in the same class.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 07-28-2012, 05:27 PM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Lightbulb Re: Just Bad Luck
Not to butt in here...
I would just like everyone to know just how LUCKY we are
here at the BIR S/SS combos
AND AS WELL, THE MIDWEST CLASS RACER S/SS combos
we DO HAVE SCALES and we DO run heads-up.
The rest is on an honor system, and if you need to cheat that bad..., well then what ever.
You are only fooling your self.
To me, without a heads-up event you may as well go bracket racing it's much cheaper and far less work.
We are truly lucky to have the events we have here,
and to have the people in place to make it all work for everyone.
Thanks...
I'll shut up now.
Glen DeMENGE
minnesota
MEXJOE is offline   Reply With Quote
Old 07-28-2012, 07:46 PM   #4
Gary H Humrichouse
Not only out of 52 cars did Caroline have a heads up but her dad had one too, the only two heads up in round one and his starter broke just before the water box thats called DOUBLE BAD LUCK............................
Gary H Humrichouse 736 STK
Gary H Humrichouse is offline   Reply With Quote
Old 07-29-2012, 01:18 AM   #5
corky
corky's Avatar
Glen I was farming and didn't get back on that post ,thank you helping with the post. Glen is Steve in or not ,call me or have him call me.Corky
