Old 07-03-2012, 12:01 PM   #1
FSA1673
Liked 12 Times in 6 Posts
Default Locking Out Advance
When you lock out the mechanical advance on a GM HEI Pontiac distributor do you tack weld it at full advance or at the initial setting?
I assume after it has been locked out you use your damper to set the timing and drop the distributor in making sure the rotor is pointed at #1. Then check the timing with a light to make sure it is ok, and make small changes with the distributor to get the exact desired timing.
FSA1673 is offline   Reply With Quote
