Old 05-27-2012, 10:35 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Powerglide input shaft spline
"They" say a turbo spline is stronger than a PG spline. Lately I had a Turbo spline shaft and PG spline shaft side by side. What I am considering is the other end of the shaft, the end that splines into the high clutches and the planet unit. Both are a coarse spline about like the PG converter spline.
So, is there really any strength gained between a Turbo spline and PG spline when the other end of the shaft has two coarse spline areas?
Just thinking.
Larry Woodfin 471W
