Old 05-27-2012, 07:21 AM   #1
drgrcr1156
Liked 2 Times in 1 Post
Question Fuel Pump Recommendation
I think I need to replace my BG500 fuel pump. It is leaking when running. The last time I had it rebuilt, it leaked as soon as I installed it. Had to return it again and it still wasn't quite right. And the service was not good either. So I swore if I had to repalce it, I would go with another manufacturer. So which is more of a direct replacement or better replacement, Magnafuel of Aeromotive?
drgrcr1156 is offline   Reply With Quote
Old 05-27-2012, 09:33 AM   #2
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Fuel Pump Recommendation
Aeromotive Hands down
DIAPERMAN is offline   Reply With Quote
Old 05-29-2012, 06:52 AM   #3
drgrcr1156
Default Re: Fuel Pump Recommendation
What would make Aeromotive your choice?
Bob
Old 05-29-2012, 08:43 AM   #4
DIAPERMAN
Reliable and service Great company.Also they are all racers at the track all the time
Old 05-29-2012, 12:06 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Product Engineering. John's a little out there but been building fuel pumps a long time.
First with SuperFlow pumps in the early 90's then he built the original BG fuel pump, 4 vane pumps, then MagnaFlow, 5 vane and now the PE, 7 vane pump
Old 05-29-2012, 04:38 PM   #6
Chuck Westcott
Chuck Westcott's Avatar
All great pumps mentioned above.
Weldon Fuel Pumps by far is the best Pump out there and offers service second to none in the industry and a LIFETIME warranty and that's hard to beat. Just go to their website
(http://www.weldonracing.com/) and read the brief on the New Sportsman Pump. If your from division 1 then calll Ken Moses as He can answer any questions you may have or Just call Weldon and ask for Jim Craig.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 05-30-2012, 07:49 AM   #7
Lou SG2340
Magna Flow worked for me
Lou SG2340 is offline   Reply With Quote
Old 06-01-2012, 08:32 AM   #8
SST159
Liked 20 Times in 16 Posts
1320racer,
I have spoken to John as well.
He comes highly recommended by some good carb builders.
What pump and filter of his have you tried or currently use?
I am concidering on upgrading to his product.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 06-01-2012, 12:19 PM   #9
1320racer
1320racer's Avatar
I run the PE 4450 combo pump and filter in my Firebird feeding 900+HP and ran the PE 4300 and his inline filter in my Chevelle with 700+HP under the hood.
Old 06-01-2012, 05:59 PM   #10
SST159
Thanks,
I am looking at the 4510 combo with filter.
Drew Wonderly
SST 159
