Old 05-20-2012, 01:26 PM   #1
Lyn Smith
Liked 1,001 Times in 203 Posts
Default stock GM front disc brake spring kit
My latest project is a 73 GM A body with the stock front disc brakes.Ive heard there is a spring kit that you can put in the caliper to take some of the drag off of the rotors.Anyone know who has these? thanks
Old 05-21-2012, 02:58 PM   #2
Jim Kaekel
Liked 536 Times in 110 Posts
Default Re: stock GM front disc brake spring kit
Lyn: I've heard of some people using clutch drum return springs from an auto trans. You would just need to find some that are the correct height to fit into the caliper.
Jim Kaekel 3836 STK
Old 05-21-2012, 06:50 PM   #3
jmdavison
jmdavison's Avatar
Liked 16 Times in 6 Posts
Check Raybestos, they have a spring for some applications...
jmdavison is offline   Reply With Quote
Old 05-21-2012, 07:01 PM   #4
Mike Fuller
Liked 203 Times in 80 Posts
Die springs work well. You have to do a minor mod to the pads. If we both end up at Joliet I'll show you what I mean.
Mike Fuller 396 STK
3961 SS
Old 05-22-2012, 05:30 AM   #5
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
ya know, i've heard of this for year BUT have yet to figure out where the spring could possibly fit to take the drag out of the pads... can/will somebody enlighten me?
Old 05-22-2012, 07:40 AM   #6
Dennis Banach
Tom,
The springs go in between the pads on the guide pins.
I ran `69 Camaro in the `70s with Factory disc before converting to drum fronts,I used the preload springs from a 12 bolt posi unit with a 7/16 washer on each end of the spring.
You do need to keep an eye on pad wear and change them if they get close to coil binding the springs.
I ran a full season with that set up and never had a problem.
Dennis Banach is offline   Reply With Quote
Old 05-22-2012, 08:54 AM   #7
Tom keedle
Tom keedle's Avatar
ahhhh, NOW i get it!
ain't gonna help me though, got ford type (think mustang II) calipers on the rambler...
Old 05-22-2012, 11:28 PM   #8
Dan Nugent
Liked 3 Times in 1 Post
I found some springs at the local hardware store that had a spring assortment. Used ones that fit the guide pin close, just enough tension to let the rotors turn freely.
Dan Nugent is offline   Reply With Quote
Old 05-23-2012, 01:10 AM   #9
Good point..Too much spring, not enough pedal (on the first pump)
