Old 05-10-2012, 09:10 AM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default Cracked C4 Case
Well I had the race car out the other weekend for the first time this year and on the 3rd pass it seems I cracked the transmission case and promptly sprayed type f everywhere. I found a very small crack about 2 inches from the tail shaft on the main case right at the top along the casting seem. I have a front engine plate, stock motor mounts and the trans uses a poly mount. I also have a really beefy JW Ultra Bell. The car wheelstands every run and I have had this set up for about 10 years and have never had a problem. This past off season I did some chassis work and added a full cage, dash bar and bars off the dash bar to the rear of the shock towers. The car leaves hard and square with no twisting. This was a new trans with less than 25 runs on it. So I am wondering if its just a coincidence that the case cracked or do I have to rethink the transmission mounting based on the more rigid chassis? It should not be solid mounted I assume. Or am I missing something else that could have caused this situation? I should add that I know a mid-plate would probably be a good idea but it's not in the budget this year.
It is a bracket car not a class car but I was curious as to what some of the Super Stock guys are doing if they have a similar set up...Thanks.
Joe Grippo is offline   Reply With Quote
Old 05-10-2012, 10:08 AM   #2
Mike Graham
Liked 341 Times in 67 Posts
Default Re: Cracked C4 Case
I run a very similar setup except with a stock rubber trans mount. No problems.
I think your problem was just luck of the draw.
Mike Graham
Mike Graham is offline   Reply With Quote
