Old 05-02-2012, 04:01 PM   #1
rod
Liked 20 Times in 15 Posts
Default 2nd. piston pin ?
sometime back i posted about shortening a pin. this is a forged TRW piston with a 3" Chevy pin.
what i want to do is place 2 .042" Tru-Arc lock rings on each side of the piston. i have now done some serious measuring and i find that there, for whatever reason, is a large amount of end play between the pin and the OEM single lock ring groove, .029" to be exact.
so, if i widen the original groove to the outside by .0275" i can get the 4 lock rings in, and not have to shorten the pin.
this leads to a whole new question. there will be approx. .0875" of material remaining between the outside of the lock ring and the flat face area [on the outside] of the piston.
the question then , is .0875" enough material to hold the ring in place and not be hammered out? currently, in unmodified form there is .111" of material.
.111"-.0275" = .0875"
thanks rod in AZ
rod is offline   Reply With Quote
Old 05-02-2012, 06:49 PM   #2
Liked 1,818 Times in 413 Posts
Default Re: 2nd. piston pin ?
Avoid using Tru-Arc retainers if at all possible. There is a very good reason that people use either round wire retainers or double spiro-locs, and it is not because Tru-Arc retainers are real reliable. Those things are "okay" at best for a stock rebuild, in a restored car that won't be driven a lot. In a modern race or high performance engine, they are a recipe/invitation for disaster.
Old 05-02-2012, 06:58 PM   #3
Marine One
Marine One's Avatar
Is a pressed pin out of the question, or maybe nylon buttons...?
Chad Sheets | STK 319 | 10.69 | 1.39
Marine One is offline   Reply With Quote
