04-10-2012, 08:56 PM | #1 |
how do i know what to pick with a converter
im going to buy a new bte converter. everyone i talked to says i need a 5500 stall. my trans guy is wanting me to get a 5000 stall. i run a 434 sbc in a 79 transam, i run a glide with a brake, shift at 6500 launch at 3500 i have a lunati solid roller cam the duration at 50 is 276/284 gross lift is 640/645 rpm range 4400-7800. ive never weighed the car but would guess around 3k. im lost with this. ive tried finding stuff on the net to read but its like a soup recipe everyone has a different opinion, if i go with the 5k what is the adverse affect of this? same with the larger stall. thanks for all your guys help i needed some expert advise so i came to the experts.
04-10-2012, 11:19 PM | #2 |
Re: how do i know what to pick with a converter
I would ask the people at BTE.
2009 V/SA Record Holder |
04-10-2012, 11:29 PM | #3 | |
I've always had good results choosing a stall somewhere between 1500 and 2000 lower than peak engine RPM. Also, better to stay with a more efficient (tight) 8" converter that can be restalled higher if required rather than a loose 10" converter that's maxed out and has horrible slippage numbers down track. Do you have a dyno sheet? |
04-11-2012, 05:05 AM | #4 |
Liked 6 Times in 4 Posts
Shift at 6500, in a sbc?
04-11-2012, 06:52 AM | #5 |
Liked 270 Times in 68 Posts
Call Charlie Plott at ATI. Your stall speed will depend on if you're going for maximum performance or something else.
Greg Hill 4171 STK |
04-11-2012, 09:18 AM | #6 |
Liked 389 Times in 168 Posts
x200!!
Ed Wright 4156 SS/JA |
04-11-2012, 10:42 AM | #7 |
Liked 10 Times in 4 Posts
Talk to Bubba Stanton at BTE and follow his recommendation. They've built many convertors for your type application and they do a real good job of it. I've sold quite a few of their converters and never a problem. JMT.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
04-11-2012, 11:30 AM | #8 |
Liked 13 Times in 7 Posts
You are best spending $400 for a half day on the dyno to determine the right converter for you engine. You will get it right the first time and it will save you a TON of money in the long run. Nothing like spending $900-$1200 on a converter and not having the right one, then having to spend another $1000 trying to figure it out.
N/A |
04-11-2012, 11:48 AM | #9 |
Liked 424 Times in 204 Posts
While I agree with those that advised speaking to Charlie Plott/ATI, the bottomline is without actual dyno info or at the very least good dyno simulation info, your sucess at getting the right converter is a matter of who guesses the best.
04-14-2012, 07:23 PM | #10 |
I just got home from a couple days of Scottys school. It was free testing of converters, carbs, fuels, trannys,etc. Alot of good products I tested 5 different converters in the last 2 days. I was able to pick up my stocker 5 tenths in the quarter mile over the converter I started with. Money well spent. Alot of work but I didnt waste any money trying to find some e.t. Its not everyday I get to test products for free. You can also learn a bit why your there.
