Old 03-25-2012, 03:19 PM   #1
rod
Liked 20 Times in 15 Posts
Default HEI w ext. coil?
has anyone used the old style [big cap] HEI chevy dist and used the adapter cap to use an external coil?
if so, 1. did it work OK? 2. is it worth the $32.00+? 3. thoughts
thanks rod in AZ
rod is offline   Reply With Quote
Old 03-25-2012, 04:08 PM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: HEI w ext. coil?
rod ,
Been using them for 20 years, no problems at all .... Just follow the instructions , I use the big Acell yellow coil .... Good to about 7,800 RPM.
Dave Ribeiro 1033 STK
Old 03-31-2012, 01:11 AM   #3
trmnatr
Default Re: HEI w ext. coil?
Originally Posted by Dave Ribeiro View Post
rod ,
X2 that coil works good, also works good on an MSD 6AL box. I currently use Crane Fireball Ignition Box, Fireball Coil and Fireball Wires, with the HEI and external coil, vacuum advance lockout "T" and mechanical advance lockout plate
trmnatr is offline   Reply With Quote
