Old 03-17-2012, 09:50 PM   #1
steve4speednova
Default starter bb chevy
i have a new #9497 powermaster starter for a 142 tooth flyweel. the starter is hitting the block. has no adjustment to turn it on mounting block. what starter will work with this combo. thanks steve
steve4speednova is offline   Reply With Quote
Old 03-19-2012, 02:05 PM   #2
njk53
Default Re: starter bb chevy
Steve, we run a 402 BB in our car and we use a GM Performance Parts starter. We have had it in and out of the car a bunch of times and have never exerienced any problems with starter to block alignment or starter to flywheel alignment issues. Actually been pretty happy with it.
Nelson Kowal
Stock 345
Old 03-19-2012, 06:56 PM   #3
monte442
Liked 3 Times in 1 Post
If you do actually have a 142 tooth flywheel I don't think there is a starter available. Normal Chevy tooth count is 153 or 168. If it is either of those would suggest looking at the one from robbmcperformance.com
monte442 is offline   Reply With Quote
Old 03-20-2012, 03:30 PM   #4
njk53
Our car has a 168 tooth flywheel. I probably would crawl under the car and count the teeth to make sure. The number of teeth matters when it comes to selecting a starter.
Nelson Kowal
Stock 345
