Old 03-14-2012, 02:53 PM   #1
racer913
Default rear gear change
I'm looking to chance the gears in 68 camaro 3300 lb car with a power glide with a 180 first gear and 30 inch tall tire right now car has 411 to 1 in it is it worth changing to 430 to 1 or will that little of gear change not make a difference
racer913 is offline   Reply With Quote
Old 03-14-2012, 11:09 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: rear gear change
Tell us a little about the engine, if you would. Is it a big block or small block? How is it equipped, and how high do you plan on buzzing it across the finish line? Many Camaro stockers will run a 4:88 gear or thereabouts. The more info you supply, the better response from the gallery on here, you'll probably get in return.
Danny Durham
Old 03-15-2012, 08:13 AM   #3
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: rear gear change
And how is it performing today? 60', 1/4, mph...
Old 03-15-2012, 04:38 PM   #4
racer913
434 small block 148 149 60 foot and motor is just under 6000 in 1/4 mile I know spinning the motor to that low RPM makes life easy for motor but i'm looking to pick up some ET I figured you guys on here made all these changes and I'm just wondering if changing the gears is worth it or I'll just rev motor higher with little to no results
Thanks in advance for the help
Old 03-15-2012, 04:46 PM   #5
racer913
mid10 70s 124 mph in good weather
Old 03-15-2012, 11:18 PM   #6
rustbucket79
Assuming the powerband doesn't fall off a cliff above 6000 RPM, more gear will certainly help, provided it doesn't create a traction issue. It could likely benefit from 4.56's. With added gearing should come a little less converter slippage as well.
rustbucket79 is offline   Reply With Quote
Old 03-16-2012, 01:01 AM   #7
Geerhead55
I agree,,a good 434 with a roller cam and good heads should pull a set of 4:56s without any problem, since you're using a 30inch tire.
I just built a 13-1 406 over the winter with a Comp roller and some 220 heads, with a 2925 Edelbrock and we tried 3 different carbs and it liked my little 750 best, which surprised us, and we buzzed it to 7400 on the dyno, since my concern was that I'm using a 4:88 gear (Dana 60) and a 29.5 tire on my '68 Nova, and I didn't want the larger motor to run out of breath, since I've always had a 355, which would rev up there just fine.
Good luck with your Camaro,,sounds like a fun car.
Danny Durham
Old 03-16-2012, 02:59 PM   #8
racer913
thanks for the help
Old 03-16-2012, 05:44 PM   #9
63corvette
Liked 359 Times in 103 Posts
Just from my experience:
My old car was a 434 SBC and made almost 850 HP
Powerglide with 1.76 gears
Car weighed 2400 lbs plus without driver
Used 16- 32 inch tires
I started with 4.86 gears and that was a little low as it crossed the quarter mile at 7600 to 7800 RPM
I changed it to 4.56 gears
That did not change the quarter mile ET times but did change the MPH by a few more MPH.
I used the same torque converter. Only change was the rear end gears.
With the 4.56 gears it crossed the quarter mile finish line at 7200 to 7400 and ran high 8 second et's at close to 150 MPH.
Just my experience.
Rick Cates
63corvette is offline   Reply With Quote
Old 03-17-2012, 01:37 AM   #10
Geerhead55
Rick,, I'm hoping that I don't go through much higher than 7200, since my car isn't tubbed and I don't have room for 32" tall tires and changing gears on a Dana 60 isn't like popping out a pumpkin on a 9 incher. I'll be a lot smarter in a few weeks. Take care.
Danny Durham
