Old 03-14-2012, 09:44 AM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Alternator ??
What ALTERNATOR is best for a car with a Elec. fuel pump Magna-fuel 300
elect. fan MSD 6-AL, and Mazire watter pump?
MEXJOE is offline   Reply With Quote
Old 03-14-2012, 10:29 AM   #2
Liked 1,767 Times in 402 Posts
Default Re: Alternator ??
Any good 60 amp one wire alternator will do the job. I like the small CS-120 series GM alternator.
Remember though, you need to put it on an 80 amp or so relay, so that your kill switch will shut the car off. A spinning 60 amp one wire alternator with an 8 gauge wire run to one battery will keep the car running after they turn the kill switch off, unless it is run through a relay or solenoid.
If you run it through a 30 amp relay, it will burn the relay and the wiring up, I've seen it done. You need an 80 amp relay and an 8 gauge or bigger charge wire from the alternator to the relay, and from the relay to the battery.
Old 03-14-2012, 10:49 AM   #3
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Also you could use a 4 pole cut-off switch and wire you MSD igntion on wire (small red wire) throught the two 10-32 termenals of the cut-off switch.
That will kill the car with a working alternator
Larry Curtis is offline   Reply With Quote
Old 03-14-2012, 11:29 AM   #4
Tim Lisson
Glen,
East Coast Alternator.
Tim
Tim Lisson is offline   Reply With Quote
Old 03-14-2012, 01:20 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 274 Times in 76 Posts
Good reliable stuff.
Sean
Sean Marconette
84 Mustang
5060 SS/N
