Old 03-13-2012, 05:39 PM   #1
Don Duke
Default XLT 350 Coan & Misc parts
1. Coan XLT 350 ultimate spragless, deep pan, trans brake, 3speed Gears 2.27-148-1-1. Freshened last year very few runs $4600 or offer
2. Precision 3 speed shifter with air shift. $350
3. Co2 shifter kit with 2 bottles $125.
4. 7 inch and 8 inch converter with PG spline make offer
5. Biondo RPM shift controller for 3 speed air shifter $100
6. 15x14 Bogart wheels chev bolt pattern 4 and 1/4 inch backspacing with 31.25x12.2x15 M/T radials $700 will separate
7. Ford 9 inch 5.63 richmond pro gear used very little $200
8. Factory 396 375 HP Alum intake #163 last 3 $210
9. 15x8 1/2 centerline warrior wheel like new 3 1/2 backspacing $300
10. 12 bolt chev 4 link rear end housing set up for 4 link, coil overshocks, comp. engineering wheelie bars, S&W brackets, 33 spine Moser axles with moser c-clip adapters, 12 bolt moser spool,& S&W brackets width 42 3/4 inch axle face to axle face. Make offer
11. Holley blue fuel pump $65
12. JE 396 375 hp NHRA legal 30 over pistons used very little $300
13. Dedenbear RTD6 delay box $110
14. MSD 6400 ignition box $90
15. 8 gallon plastic fuel cell $45
16. Edelbrock small block chev alum. waterpump make offer
Don Duke
location Iowa
Cell 515-480-6046
Don Duke is offline   Reply With Quote
