Liked 216 Times in 77 Posts
I took my drivers seat apart and put a plastic tube through the bottom of the seat so that the "crotch" strap can go through it up from its mounting point to the cam lock. I figured this would be better than running around the front of the seat and then into the cam lock. I did not remove anything from the seat what so ever. I simply slit the cushon made a rectangular tube out of a piece of thin plastic pipe. Then I took it to my local upholstery shop to have it sewn in and finshed so it looked nice and professional. My thought was that if something ever happend it would hold me back in the seat instead of letting me slide down and forward before the "crotch" strap was able to do its job. Then the other day I was reading another thread that got off track and it was mentioned that this may in fact be illegal but noone ever commented on it again just that one post. If I screwed up and ruined a seat bottom let me know. I would rather throw it away than have something thats not right. My main goal it to make to the track with this one. my second is to be completly legal and third run the index or better. If I can do all that and I enjoy the travelling I will continue to try and get faster legally. I just dont want to show up at my first race with it and be told that its a bunch of illegal junk. Thank you for your opinions
I'mnot NHRA tech but my opinion you are fine. You have not done anything to make the seat lighter, you have only made it safer. And even if tech had a problem with it, it's not a punishible offense. It would be something you would need corrected to their satisfaction before your next race.
Now go race..!
Jeff Lee 7494 D/S '70 AMX |
Liked 232 Times in 108 Posts
Did something simular to the back of my drivers seat where straps go through (instead of over) seat. Never been anything said about it.
What you did should actually be mandatory!
#5 | |
Liked 1,443 Times in 302 Posts
James Schaechter 3163 STK |
seen a lot of cars pass tech similar to yours..in IHRA.
Danny Waters, Sr / 73 Duster "340" |
Had an upolstery shop do mine almost looks like a factory job
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Mine has been like that for 10 years. You will be fine.
Joe Martens AA/Stock 3969 |
