Old 03-05-2012, 11:04 PM   #1
joelster
Default Front end settings??????
I run a 4th gen Camaro and I was wondering how much pre-load you guys like to run in your front shocks. I currently run a 275lb spring and the front end weighs around 1500lbs. It is compressed roughly 2.72" when it sits. Is that too much? Not enough? Right where you'd want it? Sitting at the ride height I want, the shock has an easy 6" more of extension.
joelster is offline   Reply With Quote
