Old 03-01-2012, 11:07 PM   #1
Gordie Kissner
Liked 18 Times in 10 Posts
Default New Hughes GM94 9" Pro IV Race Converter
NIB..Hughes Performance GM94 Pro IV 9" Race Torque Converter..Fits Powerglide w/TH350 input,TH350 and TH400. This was spec'd for a race bigblock w/glide,was told would also work well with a stroker smallblock.
This is off Hughes websight:
Hughes Performance TH350/TH400 Pro-IV Race Torque Converter
Pro-IV Series are more aggressive by design. The units are normally good for slightly higher MPH. Units are designed with more furnace brazing which produces less efficiency loss and less slippage, therefore producing higher miles per hour. This unit will still produce excellent repeatability, a must for bracket type race situations.
Anti-ballooning plate
Full roller bearing construction
Custom machined heavy duty stator
Heat treated sprag race
Fully spot brazed and reinforced impeller assembly
Fully spot brazed and reinforced turbine assembly
Heat treated forged steel turbine spline
Heat treated chromoly steel pump hub
Fully welded mounting ring
Pressure tested
Computer dynamic balancing
$800obo shipped to your door in lower 48..These are $1050 new from Summit.
Call with other questions. 208-965-0664
Gordie Kissner
SS 6010
STK 6010
Gordie Kissner is offline   Reply With Quote
