Cleaning out parts room:
5 sets of Reese Trunion style 1200LB Weight Distributing Bars. New only $50.00 per set. 5 Used snap up brackets for weight dist. hitch. $10.00 each We also have assorted enclosed trailer exterior trim and aluminum sheets to move. No white sheets left, mostly black, gray and silver. Come by and pick up or we can UPS. Mike G 703 754 4611 shop 703 675 4479 cell |
Liked 333 Times in 180 Posts
mike---ya got a p number on the trunnion bars please??? these are the round bars not the flat ones correct??? what is UPS to zip 60047?? Thanx FED 387
For the record, Cequent towing owns Reese, Draw tite and Hidden Hitch and this first set is a Hidden Hitch #111440. UPS is $29.00 bucks. Let me know.
By the way, it is a flat bar "Trunnion" style, not the round bar. Cequent has changed all these part numbers. I cant even find this online anywhere. Old inventory. These do have the radius on the chain end so you can use it on a dual cam sway control without having to add the old bolt on shoe that we used to have to add. Last edited by Mike Gardner; 02-29-2012 at 05:41 PM. |
Mike---I need one of 2 things to work with my hitch either
the round trunnion bars OR the hitch head the part the ball fastens to for a bolt together adjustable height hitch bar for FLAT bar trunnions Make sense??? The insurance company replaced my hitch with an adjustable head hitch but it is for a round bar trunnion not a flat bar trunnion-- I only have flat bar trunnions but the hitch head I have for a flat bar set up is the welded/fixed ball mount NOT ADJUSTABLE need to raise the ball up about 2-3 inches cannot do it with my setup--- can u help me?? Thanx Dick Ullrich FED387 |
Liked 43 Times in 29 Posts
Dick I've got a good used head for the flat bars and 1 good flat bar. PM me if you are interested.
Mark Ruset 2048 STK |
mark sent u a pm--Dick
headless, thanks.
thanks for your help
