Old 02-09-2012, 10:10 PM   #1
magnumv8
Default Edelbrock smallblock Mopar heads
FYI.....The first run of new NHRA legal small block Mopar heads (60767 and 61767) from Edelbrock are going to come through with the wrong sized valve guides and therefore will need to have them replaced for them to be used in stock.....Edelbrock is putting 11/32 guides in both heads when the LA used 3/8 and the Magnum uses 8mm....this issue is being addressed and will be rectified in the next run (whenever that is, they were vague on production run schedules based on how soon they would need to make more).....
D L Rambo......
magnumv8 is offline   Reply With Quote
