Old 02-01-2012, 02:44 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Chevy 350 code ?
Does anyone know what this suffix code is from a Chevy 350 T0627CNN ?
N/A
mannymen is offline   Reply With Quote
Old 02-01-2012, 03:20 PM   #2
FED 387
Liked 334 Times in 181 Posts
Default Re: Chevy 350 code ?
Tonawanda
June 27,1970
350 ci/Turbo 350 trans
TO627CNN
Old 02-01-2012, 03:27 PM   #3
FED 387
also these engines came in A/F/X body vehicles
Old 02-01-2012, 04:30 PM   #4
mannymen
Thanks for the quick response.
Manny
N/A
Old 02-02-2012, 12:04 AM   #5
killintime6968
Liked 91 Times in 29 Posts
And if you really want to get technical it was a 200hp 2bbl
killintime6968 is online now   Reply With Quote
Old 02-02-2012, 06:45 PM   #6
mannymen
Here is another one. VO627 CKZ. Regarding the heads, which are better the 882s or 441s. I assume the 441s as they are slightly larger in volume.
block..........3970010
block casting date....F264
Heads....333882
heads casting date....N264
pad near alternator.......VO627 CKZ
CKZ 1974 350 4 spd trans. J L48 195 4 Vette
N/A
Old 02-02-2012, 07:15 PM   #7
FED 387
Several answers come up for that code all are Corvette engines
V=Flint
06= June
27= 27th day of the month
CKZ=
1972 LT-1, HD 4 speed 255HP
1973 L48, 4 speed 190HP
1974 L48 4speed 195 HP
1977 L48, 4 speed 180 HP
you're gonna hafta check the block casting date/part number to say which year it is for sure--FED387
Old 02-03-2012, 10:18 AM   #8
ron mattson
Liked 69 Times in 32 Posts
Hey FED what is this code. vo426xcd any idea?
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 02-03-2012, 01:36 PM   #9
FED 387
probably an over the counter replacement engine/block or a left over engine that was put into a "next year" vehicle say a 1969 into a 1970 --since the engine code for 1970 would not be correct on a 1969 engine they used a X to denote the change---most likely an LT-1 but you'll hafta check the heads/intake to be sure
Old 02-03-2012, 01:58 PM   #10
ron mattson
FED thanks thats what i wanted to hear.
