Old 01-30-2012, 07:27 PM   #1
Duane Eiskant
Thumbs up Fuel Injector Size HELP!!
I hope this is an acceptable post?
I am currently working with a friend on a 2010 Camaro street car project that will see a small awount of time at the dragstrip. We have a LS based 427 cubic inch engine with a F1C Procharger that has a 92mm throttle body and a Fast LSX-R intake manifold. It is a pump gas engine with a 560 lift, 232 degrees duration at .050, Comp Cam and All-Pro aluminum heads. Boost will probably be in the 15 to 20 psi range. It will be tuned with HP Tuner through the stock ECM. Any suggestion on a size for the fuel injectors? I know its not stock or super stock, but there seems to be many knowledgable people on this site that I know can give accurate suggestions!
Thanks for such a great site, Duane
Duane Eiskant is offline   Reply With Quote
