Old 01-16-2012, 03:38 AM   #1
Bernhard
Default 307 olds stocker ?
Hi I have block ?. NHRA 307 olds stocker non roller engine. Are you using the factory 307 open main web block in stock or is it legal to sleeve a 330 or 350 solid main blocks?
Thanks
Bernhard
Bernhard is offline   Reply With Quote
Old 01-16-2012, 08:33 AM   #2
Billy Nees
Liked 7,656 Times in 1,726 Posts
Default Re: 307 olds stocker ?
Yes, you can sleeve a 330/350 block but I've never heard of the 307 blocks being a problem in a Stocker.
Billy Nees 1188 STK, SS
Old 01-16-2012, 12:57 PM   #3
Chuck Norton
Liked 76 Times in 17 Posts
I've seen a 307 pull the center mains out of the block. It may not be common but it can happen. It isn't a pretty picture.
c
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 01-16-2012, 05:30 PM   #4
Bunkster
Liked 43 Times in 10 Posts
Some 25 years ago, there were about 6 thousand 307 Olds stockers running around. Those motors were beat to death and proved to be quite durable.
Unless you’re using nitrous, nitro, or some other exotic ingredient, I would not be too concerned with the “windowed mains” scare on Olds motors.
Bunkster is offline   Reply With Quote
Old 01-17-2012, 03:18 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Mine is 6800 @ finish line. Oops mine is a hyd roller though
Old 01-17-2012, 09:53 AM   #6
dennis dunlap
What ,s seems to be the max you 307 builders are boring your blocks to play it safe ? Dennis J/SA
dennis dunlap is offline   Reply With Quote
Old 01-18-2012, 12:11 AM   #7
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
You should contact Don Forester. He uses Dave Smith engines and they have some of the fastest Olds Stocker stuff out there.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
