Old 12-28-2011, 11:40 AM   #1
firebird
Default cowel clearance
what is nhra's ruling on trimming the cowl on a 93-97 camaro for the g\t class. need more room for carb.the modified class is more lenient but i need clearification. any one been through this kind of build?i don't want to make the NHRA gods upset
firebird is offline   Reply With Quote
Old 12-29-2011, 09:57 AM   #2
Rusty Davenport
Liked 101 Times in 27 Posts
Default Re: cowel clearance
I used to have one of those cars, you will never be completely satisfied until you lower the engine. Your best option is to use what clearance you have and be satisfied, I found very little performance gain in clearances and playing with spacers. Cutting the hood is not an option but I have seen some that the space had been increased by flattening the hood brace a little but then you have a whole new problem. That body style is not a very good choice and very limited for any kind of carburator class racing. Modified is an impossibilty with two Holleys and even a real pain with one Holley turned sideways. The windshield also starts to breakup when you fool with the body support area under the windshield. When that motor wears out go to the LT1, you will much more satisfied.
Rusty Davenport is offline   Reply With Quote
Old 01-01-2012, 03:07 PM   #3
firebird
the only option is another model car ?
