Old 12-24-2011, 01:42 PM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Question Chevell motor mounts
Looking to put a BBC into a 66 chevelle that originally had a 283 sbc.Which set of frame mounts will work ?I am trying to keep the motor as low as I can in the chassis for hood clearance.Thanks for any input
Kevin
Old 12-24-2011, 07:16 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Chevell motor mounts
run a chevelle BBC oil pan and drop it in, you don't have to change anything else
Old 12-24-2011, 09:44 PM   #3
SSGN
SSGN's Avatar
Question Re: Chevell motor mounts
They show 2 different frame mounts in the Auslies catalog??Thats why I was curious
Kevin
Old 12-24-2011, 10:34 PM   #4
Tom keedle
Tom keedle's Avatar
if it's like camaros (i don't know for sure on the chevelles), using the small block frame mounts put's the engine further back.
i never worried about it on mine as they were bracket cars (1 was a 64 wagon and THAT'S when i found out about the chevelle pans...
big car and pickup don't fit
Old 12-25-2011, 12:33 PM   #5
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
Big Block frame mounts have a reinforcement rib around the front edge. Visually a little different but the small block ones will work.
L78 Nova is offline   Reply With Quote
Old 12-28-2011, 08:23 PM   #6
SSGN
SSGN's Avatar
Thumbs up Re: Chevell motor mounts
Thanks for the input,greatly appreciated
Kevin
Old 12-29-2011, 10:02 AM   #7
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i run the small block mounts, plus most performance header manufacturers design their headers around the small block mount/ big block combo. Lemons, hooker etc.
Ian
Ian Hill is offline   Reply With Quote
