Old 12-23-2011, 09:46 AM   #1
mike withers
Liked 3 Times in 1 Post
Question Advice on GPS units?
Looking at new GPS systems to assist in heavy traffic areas i.e. lane changes for exits,getting off beaten path & back on same,etc
I am towing box trailer with a motorhome(63 ft total).
Any suggestions or reviews based on experiences appreciated.
Mike Withers 1195 SS
mike withers is offline   Reply With Quote
Old 12-23-2011, 10:03 AM   #2
Bob Verwold
Bob Verwold's Avatar
Default Re: Advice on GPS units?
I have a Garman unit that works pretty good. I have a Crew cab truck with a 44' trailer so you have to be careful where it tells ya to turn. Mine spends a lot of time recalculating .... I've heard there is a truck version that won't take you down side streets. But it's about $1000.00 (too much for me) That's all I can tell ya, hope it helps.
Bob Verwold is offline   Reply With Quote
Old 12-23-2011, 10:28 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Bob, You should be able to go into the menu of the Garmin and change to truck mode and the shortest time. This will keep you off of the back roads and minimize the recalculating. I always check a map for basic directions on my trips then use the garmin for a back up.
Mike Pearson 2485 SS
Old 12-23-2011, 10:28 AM   #4
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
Just go onto Amazon and search "gps navigation for truck drivers" and you'll find several alternatives. Read the reviews and make your pick. You might also make sure your pick provides for regular software/road updates without charging you an arm and a leg.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-23-2011, 10:45 AM   #5
Bob Verwold
I guess my problem is, I know how to get to the tracks I'm going to. I mostly use it to keep track of the mileage on the trailer for maintenance. It does help my wife when she takes it out of the truck and uses it from time to time............
Also wasn't sure of spelling.
Old 12-23-2011, 12:29 PM   #6
mike withers
I found a truck Garmin model 560LMT priced just over $400.00 that appears to have all functions I need and has free map updates. Has anyone used this product? From what I have heard the Garmin products have a good reputation.
Old 12-23-2011, 02:50 PM   #7
Rod Greene
Liked 242 Times in 81 Posts
I have a Garmin 660 that I use on the Harleys and in my truck it works great and can be set for truck mode. I got a free upgrade for lifetime map upgrades.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 12-23-2011, 05:32 PM   #8
Rob Petrie E395
Liked 216 Times in 77 Posts
I have the Garmin model for Big trucks in my toter home and I HATE IT!!!! We also have a Tom Tom in our SUV. I wish tom tom would make a big truck model. The garmin unit looses signal all of the time and it always seems to be when there are multiple turns coming up. I sent the first one back and they sent me another one and it does the same thing. Another problem is the big truck model will not let you go in and see what roads it is taking you on like the the tom tom car units. I would stay away from the garmin big truck units ours sucks.
Old 12-26-2011, 05:06 PM   #9
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
"Mine spends a lot of time recalculating ". I hear you brother....LOL
