Old 12-20-2011, 01:46 PM   #1
eddie c
Default What to do with my good? SBC engine block!
A couple of years ago I purchased a 1969 Corvette shortblock, its a a 350ci /350hp 4bolt main motor. Upon disassembling the block I found where a wrist pin came loose and put a good scratch up and down the cyl bore. The scratch was to deep to come out in a rebore so the
machinist suggested our only option was to
sleeve the block. The block has been sitting for a few years without
any other work being done on it. I am now considering starting to
gather parts for it and having a stock elim. 350 /255 hp engine built .
My question, if everything else checks out ok on the block, would you consider this a good canidate to build or should I start looking
for a block that has not been sleeved? ed
eddie c is offline   Reply With Quote
