Old 12-16-2011, 06:26 PM   #1
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Question Honda Rod Journals
I run a 2.5 inch rod journal in a car over 3900 pounds.
If somebody is running a Honda rod size crank journal,is there a given weight where the forces of accelerating a heavy vehicle will cause crankshaft failure,or is everything safe as long as the reciprocating assembly is as light as possible?
Old 12-16-2011, 09:52 PM   #2
Chad Rhodes
Default Re: Honda Rod Journals
It has more to do with stroke and overlap of the main/rod journals.
Chad Rhodes 2113 I/SA
Old 12-16-2011, 10:18 PM   #3
Ed Wright
Ed Wright's Avatar
Yep.
Ed Wright 4156 SS/JA
Old 01-15-2012, 03:24 PM   #4
engineguy
Yep.
X3. A short stroke engine with significant main/rod journal overlap can use small diameter rod journals, regardless of vehicle weight.
I have not personally built a stroker engine with small (Honda/Quad 4) rod journal sizes, but many engine builders who specialize in strokers seem to shy away from the small rod pin.
engineguy is offline   Reply With Quote
Old 01-15-2012, 03:28 PM   #5
Run to Rund
Liked 54 Times in 27 Posts
The common mod for an Olds is to go from the 2.5" stock crank pin to 2.2" BBC size. The smaller big end of the rod also helps with cam lobe clearance with strokes longer than 4.25" on the Olds.
Old 01-15-2012, 03:50 PM   #6
442OLDS
442OLDS's Avatar
You are correct.
IF I was building a Super Stock car,I would take one of the many 425 cranks that I have and do just that!
