In rulebook,general regulations: The cutoff switch must be connected to the positive side of the electrical system. What difference if it on the negative wire?
Thank! |
Liked 11 Times in 8 Posts
Theory seems to be in a crash anything metal that contacts ground lug on battery completes the path.By isolating pos. theres nowhere for power to go... in theory. This is how it was explained to me.Joe
Joe Buchanan SS/BX 3117 |
Liked 54 Times in 27 Posts
Unlike NHRA, we know the electrons flow from the anode (-) to the Cathode (+). Since we can't teach that pig to sing, we deal with it. To protect the alternator diodes, run the feed right to the battery or the battery side of the cut off switch. For 60 amps and a lead 20' long, 4 gauge will work; crimp and solder the ends for acceptable electrical contact. Run the MSD power right to the battery to protect it. The trigger wire will go through the switched power so that will shut off the engine if NHRA just has to see if the switch shuts the car off.
