Old 12-04-2011, 02:01 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default 70-81 Camaro fuel cell install and firewall
I am looking to install a fuel cell as this winters project and have a couple questions.
How large of a cell would you recommend? The system will have a bypass regulator with return so there will be some heat built up in the fuel as it dumps over the regulator so I am not sure if a 5 gallon cell will not disapate the built up heat.
Also, when it comes to the firewall behind the rear seat and under the package tray does anyone have any pictures they are willing to share showing their firewall installed?
I am trying to figure out the cleanest install I can without it getting too complicated at the same time.
Thanks in advance.
Chad
Chad E532 is offline   Reply With Quote
