Liked 7 Times in 6 Posts
Is there a company that makes brake shoes for racing? I'd like to put primary shoes everywhere with good lining material.
Liked 56 Times in 29 Posts
I had good luck with premium ABEX organic linings on stock shoes from Ott's Friction Supply in Oregon, contact:
john andreotti <andreotti@ottsfrictionsupply.com> I also have a set of the Velvetouch linings I bought 30-some years ago, but they don't work so well until heated up, so the line lock doesn't do much. . . |
Liked 5,153 Times in 1,967 Posts
I would think you would want to put secondary shoes everywhere. Drum brakes retract so there's no drag anyway.. $.02
Liked 336 Times in 183 Posts
see if you can find a reliner that does metallic brake shoes---they do not work cold but stopping at the top end is improved the hotter they get the better they work
try CTbrakes.com they can reline your shoes ---about $75 per axle thats what they are quoting now---might be more but give em a call--
Liked 536 Times in 110 Posts
I run drums all the way around and I've had pretty good luck with Raybestos riveted shoes. I noticed that when I removed weight to move from E to D/SA, my car stopped a fair amount better even though it's only about 175 lbs. lighter. I would not recommend using aluminum drums since I developed cracks in mine and went back to cast iron. My .02.
Jim Kaekel 3836 STK |
Thanks for the replies. This is a foot brake car and sometimes it pushes the car forward when I'm staged and the rpm's are too high. I sometimes run an index class with a .400 pro tree and I need the R's pretty high. I'm thinking the extra primary shoes would help to hold it better.
I remember Car Craft or Hot Rod Magazine did an article on a brake manufacturer out of Texas that made a brake shoe with 30% better stopping power than a normal brake shoe. Just can't think of the name of the company.
Nelson Kowal Stock 345 |
#9 | |
Liked 320 Times in 102 Posts
The primary or leading shoe is the shorter shoe and the secondary or trailing shoe is the longer shoe.........
