Old 10-30-2011, 09:58 AM   #1
Michael Kilduff
Default 96-99 Chevy/GMC 3500 ?'s
I have found a few 96-99 year model GM 3500 dual wheel trucks w/454-automatics for sale and I have some questions about these trucks that some here may be able to answer.
Were there any drivetrain-especially transmission and induction/fuel delivery- differences in these years? If so which is preferred?
What kind of mileage and economy should I expect when pulling 7000 pounds on flat terrain , city and highway?
What reliability issues did these vehicles tend to have, if any?
All the ones I am interested in have 90-125K miles, look to be well kept.
Any relies will be appreciated.
IHRA STK 932 O/SA
Michael Kilduff is offline   Reply With Quote
Old 10-30-2011, 10:57 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: 96-99 Chevy/GMC 3500 ?'s
As far as I know they are all the same. The 4L80E is a good transmission. There are some good gains in the tuning. My '99 Suburban gets about ten MPG pulling my 6700 lb trailer. I would look for one with 3.73 gears, 4.10 is more common with dual wheels, but the 3.73s get better mileage. Mine sure doesn't need 4.10s.
Ed Wright 4156 SS/JA
Old 10-30-2011, 11:54 AM   #3
Rsmith38
Liked 28 Times in 15 Posts
My 96 with 454 auto 4.11 tows 26 foot 10K trailer and gets about 8 - 9 MPG. Without trailer 13.5 on highway (loaded or empty - same mileage).
Only repair in 135K miles is electric in tank fuel pump quit - $90 and 2 hours to drop tank and replace. When we bought this 454 a diesel was 10K more so even at 8 mpg we could never make up the difference in fuel. But a Cumins diesel in my buddys Dodge will get about 13 pulling 10K and as much as 18 empty. Lots more power and more $$$$.
Rsmith38 is offline   Reply With Quote
Old 10-30-2011, 12:01 PM   #4
Rory McNeil
Liked 1,104 Times in 302 Posts
A buddy of mine bought a new 98 Chevy 3500 2 wd crew cab dually with a 454 automatic for towing his 28foot enclosed trailer and race car, his setup was about 8000 lbs. He drove it every day until about 1 1/2 year ago when it was totalled in a collision. At the time of the wreck, it had about 220,000 kilomoters (130-140,000 miles), and I believe the only problems he had were intake manifold gaskets (once), A/C compressor and hoses (once), ignition swith twice, which caused the trans to not shift, and one rear axle seal seemed to leak and require replacement every now & then. After the wreck, he wanted the same type of truck, and lucked into a 96 CC dually 2wd, 454 auto, that had spent most of it`s life sitting in a barn, and only had 25,000 km on the odometer when he bought it . Its almost like brand new, however, it too had a leaking rear axle seal shortly after he bought the truck. He really likes there trucks.
NHRA 6390 STK
M/S 85 Mustang
Old 10-30-2011, 12:27 PM   #5
Dion Hildebrandt
Dion Hildebrandt's Avatar
I had a 99 gmc k2500 with the 454 and it had a hard starting problem that was almost impossible to figure out, after changing pretty much the whole fuel delivery system it was the fuel injectors themselves that were to blame. Have since found out they are a common problem on the 454's, it seems the mpfi was not properly sorted out and is somewhat of a redheaded stepchild amongst big cubic inch gm trucks. That being said I put headers and a full dual 3 inch exhaust and a healthy comp cam in this thing with a power programmer tune up, and it would tow in overdrive with out breaking a sweat. I sold it with 330,000 km's (canadian) on it and I guess it is still ticking.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 10-30-2011, 02:14 PM   #6
Ed Wright
Ed Wright's Avatar
The funky injector deal is found in the small block Vortec engines. The 454" uses eight regular individual injectors like anything else. Hard starting is usually the fuel pump. Leaking intake gaskets are pretty common. Mine, at 115,000 miles has had both. Not real common for starting problem to be the injectors. Could be the fuel used.
Old 10-31-2011, 12:31 AM   #7
killintime6968
Liked 91 Times in 29 Posts
If your having to press and hold throttle to the floor to start its usually the injectors or fuel pressure regulator. Both are quite common as is the leaking intake gaskets. I know this first hand as I own a 2000 dually with a 454. And have replaced all the above. Also having worked for GM dealers for the last 32years.
killintime6968 is offline   Reply With Quote
