Old 10-29-2011, 10:21 AM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default mallory hyfire VI problem
Took out msd 6a and installed #685 mallory box. Now tach (3905 autometer) bounces and doesnt read properly. 2 calls to mallory tech with little help. One said had to have their coil and tach adapter(what a surprise), other said shouldnt need them. One tech said to hook to negative side of coil directly (instead of tach output on box) but autometer says not to. coil is 8202 msd blaster 2. distributor is stock gm breaker point. Any ideas or suggestions appreciated. Thanks, Ron
R. Thorne is offline   Reply With Quote
Old 10-30-2011, 08:13 PM   #2
THE LEGEND
Default Re: mallory hyfire VI problem
Don't think that coil is compatible with that box.
Chip
THE LEGEND is offline   Reply With Quote
Old 10-30-2011, 09:20 PM   #3
R. Thorne
Thanks, guys. Primary ohms resistance is .7 on msd coil and .6 on "recommended" Mallory coil, so I don't think that is the issue. Will check cap as suggested and try another set of wires also. Tach worked fine with MSD last week. Is the Mallory that much more "powerful" than the MSD? Also, per Mallory instructions "do not ground to engine block, ground to frame or chassis". MSD says ground to negative terminal of battery or engine block. Thanks, Ron.
Old 11-09-2011, 10:18 AM   #4
randy wilson
Liked 22 Times in 22 Posts
He's right, coil is not right for the box. Get mallory's coil, and all will be fine. We have ran one for seven years.
don,t have one
Old 11-09-2011, 08:01 PM   #5
fredjohnston
Liked 55 Times in 14 Posts
I fought this problem with the same box. Mallory insisted there was something in the car causing it. After I made them send me a replacement, the problem went away.
fredjohnston is offline   Reply With Quote
Old 11-10-2011, 08:40 PM   #6
R. Thorne
Thanks, guys for suggestions. Tried all, and then some, no difference. It is going back to Mallory. FYI, Mallory tech line is a joke. Sam at centuryperformance is the person to go to on Mallory tech problems. Ron.
Old 11-14-2011, 12:38 AM   #7
Ryan Horensky
Liked 109 Times in 18 Posts
I had a similar problem. We have Hyfire 6 boxes in both our cars. I bought one in 2006 at Maple Grove and had zero problems with it in 5 years. We had our Crane box go bad in the other car and replaced it with a Hyfire 6. Third time was a charm. I had to send back two boxes that were bad. It may be possible that Mallory had a bad run of boxes. The last one they sent me works fine. It was needless to say a long season dealing with bad electronics.
Ryan
Ryan Horensky is offline   Reply With Quote
