Liked 101 Times in 27 Posts
Lets hear it you guys----this is not for 16 volt enthusiast-----12 volt only---what is the best ???
Liked 535 Times in 110 Posts
If you want a lightweight 12-volt, I've had very good luck with Braille.
Jim Kaekel 3836 STK |
Liked 3,227 Times in 981 Posts
Optima pays contingency and I've had good luck with them.
Liked 886 Times in 238 Posts
Optima red top ...Not as light as the Braile ,but
great for cars that spend long periods of time between being driven. not good without an alternator, longer charge recovery time than Yellow top
Liked 71 Times in 38 Posts
X2. I've had an Optima yellow top in my car for over five years.It's heavier than I'd like ,but always recharges quickly (no alternator) and it will start the car without assistance after sitting for months at a time.
Liked 26 Times in 8 Posts
OPTIMA yellow top and they have a lightweight yellow top now available. Red top Optima in your tow vehicle.
Phil
PHIL VELDHEER 3455 STK IHRA WORLD Record Holder 2007-08-09-10-11-12-13-14-15-16 |
Liked 126 Times in 61 Posts
Optima batteries are the way to go. Yellow tops are the best forracing whether you have an alternator or not. When you charge them they are sensetive to a higher voltage charge, they don't like seeing over a 14.7V. You can put 200 amp. thru won't hurt them at all but high voltage will. Battery tender 5amp is all you need. If you need to charge quicker just watch the charge voltage. I work for the company that owns Optima.
Liked 334 Times in 181 Posts
DEKA makes the Braille battery look at their site ---gives ya the real CCA's etc not the hyped up that Braille gives ya also about 20-30 % cheaper vthan the REBAGED braille battery
I found this on yellowbullit has anyone tried one yet.
Default Dyna Batt Review I just wanted to give my opinion on the dry mini battery, I call it, from Performance Distributors. They are the guys that make the DUI line of HEI stuff and wires. They are local to us here in Memphis, so I stopped by and picked one up. They only weight about 12 lbs and they have a couple of different terminal configurations. I installed one a couple of races ago along with a 105 amp alternator (a higher amp alternator would be nice). So far, it has been great. It starts the car fine and runs my fuel injection/nitrous solenoids/ fuel pumps, ignition just fine. I'm sure the car basically runs off the alterantor when it's running though. I usually hook up my charger between rounds because I have 2 dc bottle heaters I use in the car and they will kill pretty much any battery. I had the relay that goes to the bottle heaters weld the contacts together and it was on for quite a while before I found it. Amazingly my burst disk didn't blow. It completely drained the battery and I thought I was done for the day, but I put my charger on it and in 30-45 minutes it was topped of and started the car. I was amazed! I just thought I would give my opinion/review of these little batteries. http://www.performancedistributors.com/batteries.htm
Alan Warman STK 4107 |
#10 | |
Liked 282 Times in 103 Posts
I have one of those and I never had any problems with it.I only use it once in awhile if I am trying to get weight out of the car.For everyday round robin bracket racing,its hard to beat an Optima battery. |
