Old 10-01-2011, 10:29 AM   #1
Jim Storms
Liked 4 Times in 2 Posts
Post Superstock A Body oil pans?
Curious on the pan of choice for a smallblock mopar in a A body with stock K member and suspension. Superstock engine......
Jim Storms is offline   Reply With Quote
Old 10-01-2011, 09:11 PM   #2
STK4340
Default Re: Superstock A Body oil pans?
For comparison, I tried a super stock Milodon pan in which the center-link goes thru and also a Dakota pan; no difference in e.t...low 10's
STK4340 is offline   Reply With Quote
Old 10-01-2011, 10:29 PM   #3
Jim Storms
don't want to mess with link, Dakota has been my first choice.
Old 10-02-2011, 03:00 PM   #4
Ken Etter
Liked 87 Times in 9 Posts
I think we have a milodon laying around and maybe a couple of aluminum pans with a pass thru if interested.
Ken Etter 7375 STK/5 SS
Ken Etter is offline   Reply With Quote
Old 10-02-2011, 03:25 PM   #5
Jim Storms
Cool Re: Superstock A Body oil pans?
Thanks Ken, im really trying to avoid going trew the pan if all possible. im puttin the 318 from the avenger in our 71 Duster, ive never had any oiling issues since i got it from Bogner and would love to keep it that way. ill give you a call befor i head to Vegas and maybe you can bring one with! thanks Jim.
Old 10-02-2011, 11:28 PM   #6
Phillip marvetz
Phillip marvetz's Avatar
I just bought one of those Kevco pans for an A body, Looks pretty decent. I don't know about the fit yet though.
2009 V/SA Record Holder
Old 10-06-2011, 07:35 AM   #7
ScottHall
Jim,
What size engine is this?
Scott Hall
Moroso Performance
ScottHall is offline   Reply With Quote
Old 10-06-2011, 09:42 PM   #8
Jim Storms
Originally Posted by ScottHall View Post
Jim,
Scott Hall
Moroso Performance
It's the 318 that was in my Avenger.
Old 10-08-2011, 11:15 AM   #9
LXguy
I've got a Kevko pan on my Dart with a 360 (they make a 318/340 as well). Its not a "through the pan" deal. I am running stock K-member, stock steering, etc.
Fits very well, has a drain plug at the top of the sump for easy "set on kill".
It fits Hooker Super Comp headers, though you can't use the higher drain plug with them as a tube is to close, but the lower one obviously still works. It fits regular Hooker Comps as well.
They are not adverse to "making it your way" if you want something different.
Its got trapdoors and good baffling. Maybe not the prettiest thing on earth, but you can't beat the price.
Make sure you clean it good before putting it on. There were a couple of (tiny) pieces of metal in mine.
www.kevkoracing.com
Good Luck
LXguy is offline   Reply With Quote
Old 10-08-2011, 09:17 PM   #10
Jeff Teuton
Liked 325 Times in 50 Posts
We could not get a Dakota on my 70 Duster. I think some of the a bodies moved the steering stuff, we use a Moroso 8 quart that we shortened 1" fits in front of the steering, and is even with the x member for the occasional wheel stand. I can tell you, the dakota pan with a couple quarts out is worth a tenth. Won't hurt nothing.
Jeff Teuton 4022 STK
