Old 09-26-2011, 08:32 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Question convertor flash
I checked my convertor on the return road in hi gear and it went to 5300 How do you know what your combo should have ? I shift at 6700 and go thru top end at 7200, I don't 60' as well as i should . . Any help appreciated . Mike
Mike Savelle is offline   Reply With Quote
Old 09-26-2011, 09:17 PM   #2
Liked 5,147 Times in 1,964 Posts
Default Re: convertor flash
Mike, You want to it flash to peak torque or just a little higher.
Seeing you're multiplying torque at roughly 2 to 1 , you want to launch with all you got!
Now, in the absence of a dyno sheet, I suppose you could talk to guys with similar combos, or plug your specs into one of those computer calculator programs and hope for the best.
You can PM me for more info if you'd like .
Old 09-27-2011, 02:14 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
Just a guess but I would say about 5800.
2009 V/SA Record Holder
Old 09-28-2011, 12:35 PM   #4
Mike Savelle
Smile Re: convertor flash
Thanks for all the great info ..........
