Old 09-23-2011, 06:31 PM   #1
rod
Liked 20 Times in 15 Posts
Default SBC block filling ?
i have a 60 over 327 to assemble. i would like to fill [hard block or?] this block to the bottom of the water pump holes. i understand you can put a plastic tube in the water jacket to use the lower block drain.
if anyone has personally done this, would you either explain here in detail or e-mail me.
also what brand is the best?
thanks rod in AZ
hugunin@frontiernet.net
rod is offline   Reply With Quote
