Liked 2 Times in 2 Posts
What are you guys/gals using to prevent heat buildup near fuel lines? What are you using to cover fuel lines?
Your help would be appreciated. Mike |
Liked 129 Times in 59 Posts
I've been using the poly insulation you can buy at the home improvement big box stores, looks like rollbar padding but smaller. It's pre-split, conforms to the fuel lines easily, and I can cover it with duct tape to keep it in place.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
i wouldn't route that near anything hot
Chad Rhodes 2113 I/SA |
I guess I should explain that I'm still using a mechanical pump, so the line from there to the regulator and carb aren't that close to headers.
Sorry for any confusion! Lew
Liked 20 Times in 15 Posts
My neighbour is an insulator and he gave me a roll of asbestos that they use for wrapping high temperature pipes. It is sort of like split loom and I use stainless tyraps to hold it on. It has a coating on it so no fibres come off.
You can lay it right on a header and it is cool on the other side. Allan Last edited by 55 Chevy; 09-14-2011 at 10:32 AM. Reason: Added more info. |
Liked 5,121 Times in 1,952 Posts
Liked 14 Times in 3 Posts
Apparently your neighbor hasn't been reading the news or watching t.v. the last decade or
so. Asbestos causes CANCER !!! Asbestos is illegal !!! GET RID OF YOUR NEIGHBOR HE'S DANGEROUS.
Austin Weidhaas 1368 STK |
Liked 5 Times in 3 Posts
I have mine from the reg(on the fender well) to the carb in the same stuff Lew.
you're joking right?
Thanks guys for your interest in this topic!
I was thinking along the lines of the poly wrap from the big box stores but the stuff looks like what bracket racers use for roll bar padding.AND I have seen what fire does to that stuff. As for asbestos, well I'm not going there...thanks anyways. Bickel and Rick Jones sell a wrap which needs to be used when your braided lines and fittings are made. Any other suggestions? Mike |
