Old 09-11-2011, 01:36 PM   #1
chevy 68
chevy 68's Avatar
Default valve sprig life
BB Chevy 502 crate, stock, comp cams spring 2 yrs old. Springs tested between 200-240, I assume a bad one would be about 160?
Thanks,
Bob Smith
chevy 68 is offline   Reply With Quote
Old 09-11-2011, 06:02 PM   #2
daninline
Default Re: valve sprig life
Bob it looks like the factory springs are around 130 to 140, 200 to 240 seems way to much for a hyd lifter. the big question is will it cause a intake pop on the upper RPM range like you have seen....
daninline is offline   Reply With Quote
Old 09-11-2011, 06:08 PM   #3
chevy 68
chevy 68's Avatar
so how long do springs last?
Old 09-11-2011, 07:51 PM   #4
daninline
forever just keep lowering your shift light RPM's
Old 09-12-2011, 07:50 PM   #5
72Malibu
72Malibu's Avatar
I'm using Brodix' GA1000 springs on their racerite heads .708/.708 solid roller and I get 2 yrs out of them. 450-500 passes.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
