Old 08-24-2011, 10:06 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default swapping rear tires side to side
I do understand swapping side to side is recommended, at least by Mickey Thompson Tires. I do as recommended, usually swap them after each race.
But each time they are moved it is two runs before the tires resettle back in.
Many times, two runs is all we get before first round. Thus, there is that "little thought" for first round, "are the tires back to the number?"
So, let me hear your experience. Do you, or do you not swap? Do you also experience that two run back to normal issue?
Larry Woodfin 471W
