Old 08-22-2011, 10:29 PM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default BBC exhaust header gaskets
I've been experiencing a problem with my header gaskets blowing out on my '88 R20 Suburban with the 454/T-400. I'm using Hedman Super Huslers with thick flanges and the high temp coating. I'm towing a 21 foot steel deck trailer with about 4200 lbs of race car and equipment. I've attempted to cool the motor down with a thermostat change, and it normally runs about 180 -190 degrees under load. I've tried a number of gasket types, but after a few weeks or so, I'll get a section of gasket blown out!
Has anyone had a similar experience? Any recommendations on a type or brand of gasket you've had any luck with?
Thanks for your help!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 08-22-2011, 10:33 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: BBC exhaust header gaskets
pull the headers off and have the flanges resurfaced probably not flat so it eventually burns out the gasket--- got a "booger of weld" in there that is not allowing the flange to seal against the head--I know itsa a pain to fix but do it and ya probably will never have to fix it for a long time
Old 08-23-2011, 01:28 PM   #3
Bill Baer
Lew
FED's advice is sound you might want to consider trying a set of copper header gaskets while your at it too. Besure to retorque the bolts after a couple of heat cycles when the motor's cool.
Old 08-23-2011, 08:48 PM   #4
Lew Silverman
Thank you so much for the advice. Upon further examination, it looks like a bolt has stripped out of the head on #4 cylinder, so the hedders will have to come off anyway! But at least I won't have to remove much to get to the head, there is still something to be said for working on 23 year-old vehicles!
Thanks again!
Lew
Lew Silverman #2070
Old 08-23-2011, 11:25 PM   #5
Run to Rund
Liked 54 Times in 27 Posts
x2 on copper gaskets!
Old 10-26-2011, 07:58 PM   #6
RACER1530
RACER1530's Avatar
Send a message via AIM to RACER1530
you might want to cut the flange so that the other tubes dont influince each other
Fordyce Motorsports
SC 1538 / SC 153R
RACER1530 is offline   Reply With Quote
