Old 08-21-2011, 01:56 PM   #1
rod
Liked 20 Times in 15 Posts
Default 9" ford ?
for some strange reason the pinion support 'O' ring is leaking. is it possible to pull the support out, replace the 'O' ring and reinstall the support? it would certainly be quicker to the 5 support bolts than to have to pull the third member.
i run a 5.67 gear so the pinion is small with 6 teeth
any help will be greatly appreciated.
thanks rod in AZ
rod is offline   Reply With Quote
Old 08-21-2011, 04:23 PM   #2
Maverick
Liked 36 Times in 26 Posts
Default Re: 9" ford ?
Do you have a after market pinion support, Like a MW? I had a similar problem and had to RTV the spline on the pinion, where it slides into the yoke. The lube was actually coming through the spline and yoke. I had a leak and chased it for a while, and had to do it on two different center sections, both have after market pinion support/bearing And I would pull the third member to fix the leak. You might be able to get away with just pulling the pinion support, depends on how lucky you are.
Old 08-21-2011, 10:33 PM   #3
Robbie Draughon
Liked 29 Times in 5 Posts
I've done it before without removing the 3rd member. You just have to turn the pinion as you push it back in the housing. Getting the tail bearing lined up can be a little tricky.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
