Old 08-18-2011, 10:04 PM   #1
Charlie Ford
Default Wilwood brakes?
Anybody got any experience with Wilwood Disc brakes? The one's on our car seem to drag. They've been on there for some time. Anybody??
Charlie Ford is offline   Reply With Quote
Old 08-18-2011, 10:14 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Re: Wilwood brakes?
Check with Alex Denysenko (page 2 of parts classifieds) he just changed his Wilwood calipers to some trick quick release type.
Old 08-19-2011, 02:00 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
I have a rear set on one the dusters that gave me some grief, I bought a new set of pads and a seal kit, So far the problem has gone away. The old pads had uneven wear.
2009 V/SA Record Holder
Old 08-19-2011, 07:56 AM   #4
Kirk Morgan
Liked 81 Times in 45 Posts
You need to open the bleeder on the caliper and see if the drag goes away. If it does you have a hydraulic problem. If not the problem is in the calipers them selves. Get a overhaul kit for them. Remember the the oring flex is what help pull the pistons back in when the brake pressure is released. If you have a hydraulic problem most likely it is the master cyclinder or the brake pedal linkage binding. There is a small chance it could be the rear brake hose. To test the brake hose open the brake line at the master cyclinder for the rear brakes is the brakes are still dragging you have a brake hose problem. Hope things are going well see you in Houston?
Kirk Morgan is offline   Reply With Quote
Old 08-19-2011, 01:34 PM   #5
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Depending on their age you may want to replace the pads and seals especially since you're having a problem. With new pads, etc, make sure the calipers are aligned perfectly. I had to shim mine to prevent them from draging on one side while the other had plenty of clearance. The alignment is not necessarly correct due to varances in the mfg and vehicle. The varance was so slight I used shim stock to move the caliper into alignment.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 08-19-2011, 06:22 PM   #6
Charlie Ford
From day one, the front wheels wouldn't spin freely. I wrote it off as being new. I thought they "wear-in" so to speak. We've got 200 runs on 'em and they still drag. They actually act like they're self adjusting. I've got to replace the rear gear "if" we try to run Houston, so I thought I would look at all the brakes. Since it's done it from the start, I may need to look at the play in the brake pedal??
Old 08-21-2011, 02:00 PM   #7
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Charlie,
Give me a call.
219-861-1214 days
Or e-mail anytime
monymkrssla@aol.com
All you need to do is rebuild the calipers.
I will walk you through it. About 4-5 hours of your time and 4 Wilwood kits.
We have the kits in stock. About $50 delivered for all 4 wheels.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 08-21-2011, 04:01 PM   #8
Pvt Parts
Pvt Parts's Avatar
Master Cylinder overfull?
M/C Bleed back orifice clogged?
New Pads?? I always cut .030 off of new pads before installing them.
Old 08-25-2011, 08:45 PM   #9
Charlie Ford
Anybody know about removing a "check" valve type apparatus from the stock master cylinder when using it in "race car" apps.??
Old 08-25-2011, 09:41 PM   #10
63 savoy
63 savoy's Avatar
Try to keep the wheel bearings loose if it is a race car--the extra run-out will push the pads back.Works for me--Mike
63 savoy is offline   Reply With Quote
