Old 08-17-2011, 09:33 PM   #1
vetteboy
Liked 2 Times in 2 Posts
Default Fuel pressure
What should I set the fuel pressure at for a carter wcfb. It is on a 327 250HP pure stock.
Thanks Brett
vetteboy is offline   Reply With Quote
Old 08-17-2011, 10:37 PM   #2
tj310
Default Re: Fuel pressure
We run a 4gc Rochester 4.5 works OK probably no more than 7...Thanx Trevor
Old 08-17-2011, 10:50 PM   #3
Steve Hurley
Liked 4 Times in 2 Posts
I run 10.5 lbs. on the wcfb to keep the fuel level up after launch.
Steve Hurley is offline   Reply With Quote
Old 08-18-2011, 09:16 AM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Fuel pressure
Steve is right, but it depends on what's done to your carb ?
How pure is Pure Stock ?
Dave Ribeiro 1033 STK
Old 08-18-2011, 04:14 PM   #5
vetteboy
The only thing I have done to it was a rebuild,removed the metering rods and different jets.
Old 08-18-2011, 06:23 PM   #6
Dave Ribeiro
What else did you do to the rebuild ? Bigger needle & seats, replace gaskets, check surface straightness, etc ? That's why I asked about what you can do to Pure Stock rules.. There is a big diifference between a rebuild & a race carb from a good builder ? You should see if a local racer has tricked out Race WCFB carb you can try ... I know you will see a big difference , there's alot of inturnal works that you can't see from the outside ? Check-around , I am sure there are some Stock & S/S guys that can help you in your local area... Alot depends on the car & how hard it leaves, Stick or Auto ??
Good Luck ...........
